Stuck clutch
jeff
02-27-1999 20:44:20
Just bought a To-20 that has been sitting for about a year outside... The clutch will not disengage. Any ideas on how to free it up without seperating the tractor???
steve
02-01-2000 06:16:18
 Re: massy harris 44 diesel in reply to hans christiansen, 01-31-2000 16:30:05
The M H part number is 761 923 m1
RMD
02-28-1999 08:16:39
 Re: Stuck clutch in reply to jeff, 02-27-1999 20:44:20
The first thing to try is to start it up and once it is idling smoothly, try to slip it into first gear. Often the shock of going into gear will break the clutch loose. If not, drive around in first with the clutch depressed for a while. If it doesn't break loose then you'll have to go to more drastic measures. I know that on some of the old fords that there was a spot that you could drill a hole into the case and pry the clutch loose.
