MF 135 running puny! Help!!
Richard in In
12-04-2002 18:53:40
After running my 135 (gas) for 15-20 min. it had been missing, back-firing, smoking black, dying and not re-starting until it cools down. We did some work on it including, re-building the carb, cleaning the gas filters, new intake/exhaust manifold and gaskets. It runs better at times then others it does the same thing. Could it be an ignition problem too? Any ideas???
jack
12-06-2002 13:50:07
 Re: MF 135 running puny! Help!! in reply to Richard in In, 12-04-2002 18:53:40
Fisrt thing I'd check is the plug wires ,on my 3 cyl.perkins the distributor rotates counter clock wise ,if that's not the problem ,lucky for you BIG DEAN is back from holidays best of luck.
