I think the Hydraulic unit is shot on the Masssey.1) Checked fluid,the level was fine but I did notice it looked a little milky. I am wondering if water got into the case somehow and mixed with the oil and the water froze the pump and damaged it? 2) I noticed that when I disconnected the plow the three point would not got all the way down, so I moved it in the garage and turned the heat on and after about an hour it dropped down all the way. I am guessing it only moved about 3-4 inches but it still was hung up on somthing. 3) Now, I fire up the massey and try to move the plow up and down and nothing happens except I do hear a faint noise like a bubbling noise or somthing. 4) I shut off the engine and manually lift the three poit and there is no resistance what so ever, and I can go from stop to stop. It's dead. I did notice somthing. when I get somewhere in the middle of the travel of the three point, I can feel a metallic clicking noise, It is very faint but definitly repeatable. 5) This is my diagnosis>>>>>>> Maybe a relief valve is stuck open? Filter plugged? Broken parts$$$$$$?
