Mf-10 ignition
jerry
02-27-1999 05:35:01
the solid state ignition is burned out on my mf-10
i need another way to fix it other than buying
another 90 dollar magnito please someone tell me how to rig something up to this engine that
has no place for points
Gerald J.
01-31-2000 20:51:27
 Re: mf35 delux transmission in reply to Jeb, 01-30-2000 09:48:10
If you have multi-power, it can act as a hill holder when in high range that make for really tough shifting.
The transmission is not synchronized or constant mesh, the gears are straight cut gears and slide to mesh and unmesh, they don't always go straight in.
Otherwise tough shifting probably is a sign of the clutch not releasing fully. That can come from misadjustment (too much free play), a warped clutch plate, goop on the clutch plate, or a failing pilot bearing.
Make sure you have the right amount of free play before you get wild with the other stuff. You can polish a sticky clutch plate that's not warped by putting the tractor in the highest gear, locking the brakes (maybe with the nose solidly against a LARGE tree) and slipping the clutch until it gets hot. You can also warp the clutch plate by overdoing the heating.
Gerald J.
