Line on a 1970 MF 135
jeff
11-26-2002 15:36:29
I've got an opportunity to pick up a gas 135 in good condition but don't really know where to start with the bidding. Comes with a loader. Seems to be in good condition. Left brake's not working due to being wet with hydraulic fluid. Smokes a little.
Any ideas? Thanks, Jeff
Wayne in Tn.
11-26-2002 18:38:50
 Re: Line on a 1970 MF 135 in reply to jeff, 11-26-2002 15:36:29
Sounds like bad axle seal probably caused by worn bearings.Engine more than likely needs rebuild.I would start around $1,000 and work up to your limit.I hear those axle bearing can be fun and I don't know what a rebuild kit would cost along with any machine work. Keep that in mind when you set a limit.Perhaps you will get more opinions to help. Good Luck!Get with Big Dean.
