My 165
Matt
11-26-2002 09:53:40
I have recently bought a 165 and when i got it the bloke told me the rear hydraulics did not work i have got a suspicion the pump has gone but multi power does not work either is multi power hydraulically operated if so does it run off the same pump as the rear hydraulics or another one
Gordon Lueder
11-28-2002 08:12:05
 Re: My 165 in reply to Matt, 11-26-2002 09:53:40
There are two pumps in the trans. There are metal screen washable filters on the hyd pumps. You can get at them through the side cover right side. Check that and oil level. If that is ok see if pto turns.If everything is working hang onto pocket book.
Matt
11-28-2002 13:08:46
 Re: Re: My 165 in reply to Gordon Lueder, 11-28-2002 08:12:05
Thanks for the help gordon i have now stripped out the rear end of the tractor it turns out that the pump is driving it was just that the oil filter was clogged up solid it looks as though the multi power is running of the main hyd pump is that possible or not?
