M-H 44 not charging
Pete
11-25-2002 09:33:29
How do I check to see whats wrong with the system. Is the generator ar the regulator bad? Is there an easy way for me to check without a lot of gizzmo's? Thanks
Allanc
12-01-2002 16:15:13
 Re: M-H 44 not charging in reply to Pete, 11-25-2002 09:33:29
Well sorta! Ground the field terminal and see if the generator charges. If it does, the problem is regulator. The other easy test is take off the belt and put power to the armature terminal and see if it tries to motor. If it does the generator is likely O.k. If not, it's time to check brushes and things that are simple. If it all looks good you need someone with some equipment and knowledge to check it out.
