Massey 1100 pto
Jim
11-24-2002 18:38:30
PTO quit on my friends 1100 Massey. The hydraulics still work. He has the ground drive pto option on this tractor. He was grinding feed and the pto just quit. his pto now does not work when the lever is placed in engine or ground drive position. Any ideas?
Jim
Lynch
12-10-2002 01:11:19
 Re: Massey 1100 pto in reply to Jim, 11-24-2002 18:38:30
I can get him a Original 1100/1130 parts manual, if that would be any help. It's about 700 pages,though.
Charlie
12-03-2002 17:35:00
I have a MF1100. This tractor has a hyd clutch pack inside just below you feet. If neither the ground or hyd pto will work, I recommend removing the pto housing on back of tractor a do a good visual inspection. Then you might need to remove the top center hyd cover to see the hyd clutch pack. This tractor has 2 hyd pumps. one under you feet and one on front of engine. The one under you feet works the multipower and pto clutch pack and feeds fluid to front pump. Where do you live? Iam in San Antonio TX. You might try and email Big Dean at [email protected]
