MF 135 Tachometer
John Grappone
11-24-2002 14:51:09
Have a 135 Deluxe with continental z145 engine. it has a tachometer/ pto speed guage. I have a new cable but can not find where it goes on engine. It does not hook lup the the back of the motor and does not hook up to the generator although the cable is long enough. Any ideas would be appreciated.
Marcel Gosselin
11-26-2002 12:49:31
 Re: MF 135 Tachometer in reply to John Grappone, 11-24-2002 14:51:09
Later model 175 had an alternator c/w gear for driving the cable. As said before should of hooked on the back of the genreator on the continental
John G
11-26-2002 14:57:55
 Re: Re: MF 135 Tachometer in reply to Marcel Gosselin, 11-26-2002 12:49:31
Apparently it went on the back of the generator. Unfortunately this generator must have been replaced and the shaft is not tapped for the gear that drives the gear assembly. I don't have the gear assembly either. Anyone know where I can get a generator shaft or generator that is taped or a gear assembly.
chris mf35
11-25-2002 17:04:37
welcome to the common problem. it came with a generator had tach drive on back of it. most have been changed to alt, thus loosing the drive. later model 235,s with alt had a drive on the dist. good luck.
John Grappone
11-26-2002 04:57:03
 Re: Re: MF 135 Tachometer in reply to chris mf35, 11-25-2002 17:04:37
Mine still has the generator. I am going to the MF dealer today to see if they have any ideas.
Thanks for all the information.
Hawk
11-25-2002 04:45:29
My book shows it going into the left side of the block between the starter and distributor.
Paul
11-24-2002 20:32:39
Try Big Deans site. If he cant help..no one can. Good luck
Scott from Pa.
11-26-2002 15:36:01
 Re: Re: MF 135 Tachometer in reply to Paul, 11-24-2002 20:32:39
Big Dean went away for the holidays. Don't know when he will return.
