What polarity on my MF 135 1966
Christian
11-23-2002 13:32:37
I just bought a MF 135, and i see that the +from the battery is connected to ground.(Tractors body)
Is this right?? Everything seems to work, even charging.
mhmalcolm
11-28-2002 05:41:01
 Re: What polarity on my MF 135 1966 in reply to Christian , 11-23-2002 13:32:37
As a general rule, if your tractor is equipped with a generator, it is positive ground. If it is equipped with an alternator, it is negative ground. There are very few exceptions to this rule. I do know that any Delco-Remy generator equipped system is definitely positive ground.
Paul
11-24-2002 20:14:46
Mine is a '67 135 & it is a negative earth.Your system must be wired opposite to factory specs. Try Big Deans site for more accurate info.
Bill in TN
11-23-2002 15:41:19
My 135 isn't like that....- goes to ground on the engine block.....
