Pony hydo leak
Nathan
11-23-2002 09:30:41
Does anyone have a Pony with hydraulics that would be able to help me with a control valve leak? Thanks all.
Jason
11-25-2002 17:47:33
 Re: Pony hydo leak in reply to Nathan, 11-23-2002 09:30:41
Where is it leaking exactly? I have had nothing but problems with mine. There are small O-seals in the control valve. There is also a gasket where the lines screw into the control valve. Mine has a habit of leaking every now and then. I take it apart clean it and put a new gasket in. It last a while then leaks again. It will leak more when I run the tractor harder.
Nathan
11-26-2002 05:14:24
 Re: Re: Pony hydo leak in reply to Jason, 11-25-2002 17:47:33
Mine leaks where the lines bolt to the valve. I put an o-ring in the groove for the pressure line, and a home made gasket for the whole plate, but it seems as the gasket keeps the o-ring from sealing because of the extra thickness added. It will work fine for a couple uses and then I take it apart and the o-ring is shredded from hydro pressure. All of the manuals really dont show the gaskets and stuff. Any Ideas? Thank you for your help.
