Mf 1035 plug for block heater?
mike c
11-23-2002 06:55:57
I just purchased a used mf 1035. It has a plug
for what appears to be a block heater. The owner
said you should just plug it in for 20 min. or so
Is this correct? There is nothing in the manual.
Hawk
11-23-2002 08:11:25
 Re: mf 1035 plug for block heater? in reply to mike c, 11-23-2002 06:55:57
I just put one in my 245. It should be a 600 watt heater so use a good extension cord. Depending on temperature, 20-40 minutes ought to do it.
If it's working properly, the block should get real warm near the heater after a couple of minutes. The cord will get warm too.
Charlie
12-03-2002 17:43:15
 Re: Re: mf 1035 plug for block heater? in reply to Hawk, 11-23-2002 08:11:25
I have put one of these 600watt heaters in my MF65 and MF1100. The amp draw on 120 volts is about 5 amps. The instruction sheet said to use at leat 50% antifreeze. I usuall plug mine in for a hour to hour and half. If your heater is in plug just aft of injector pump it might be different wattage. You could use a timer on extension cord to turn heater on and off. I believe you a better off using the heater than ether!!!
