Z134 Rebuild
Iowa Dave
11-21-2002 06:32:35
I have a Z134 Continental 4 cyl gas engine I'm rebuilding. Currently waiting for parts to arrive(cam, sleeves & pistons, governor). Anybody have any advice on what sealants to use where? Particularly around the o-rings at the bottom of the sleeves?
Bob in CA
11-21-2002 07:04:07
 Re: Z134 Rebuild in reply to Iowa Dave, 11-21-2002 06:32:35
Everybody has their own beliefs on sealants and swear by them. I always use non-hardening sealants for everything. In fact I use one in particular almost exclusively called Tite-Seal. This is a thick sealant that comes in a can that you spread by finger in a very very very thin layer on the mating surfaces of the parts. I never have leaks. Period. This is the stuff that many aircraft engine rebuilders have used for decades. On the sleeve o-rings first use a wire wheel on a drill or pneumatic tool to thouroughly clean all of the contacting surfaces and then lightly coat the surfaces and o-ring with a light mineral oil like 3 in 1 or marvel mystery oil. Sometimes it helps to freeze the sleeves before installation but I forget off-hand what the clearance is for the Z-134.
Bob
