Tach drive Out?
Tom
11-17-2002 20:12:07
I have a tach problem I changed the cable and noticed the drive gear is not working .Does anyone know if that gear is nylon or what and if they go out when something like a cable getting into the fan belt???
Bob in CA
11-19-2002 17:35:24
 Re: tach drive Out? in reply to Tom, 11-17-2002 20:12:07
Tom,
Info on the model of your tractor would be helpful in answering your questions as there are many different styles of tach drives out there.
Norm
11-17-2002 20:32:55
Tom, I assume you're refering to a Tractormeter kind of tach running on a TO 35?
If this is the case, you can easily test the drive by not connecting it to the tach and check rotation. The tach itself can be rotated with cable using pliers and rotating by hand. Post back your results.
Good Luck
Norm in Ont.
Tom
11-17-2002 21:10:49
 Re: Re: tach drive Out? in reply to Norm, 11-17-2002 20:32:55
Well Tach works and drive appears not to turn
I was wondering if the gear can strip or something like that.
Tom
11-18-2002 23:13:24
 Re: Re: Re: tach drive Out? in reply to Tom, 11-17-2002 21:10:49
There is a blade on the end of the drive gear that shears off and, is this blade replaceable
or do I replace shaft and all???
