MF 35 v MF 148
John in NZ
11-15-2002 22:28:31
Can anyone tell me the HP of the 148 and what are the main differences between these two tractors .I beleave that they both use the same perkins 3 cyl diesel ,is this correct.Thanks.
bg
11-16-2002 16:45:18
 Re: MF 35 v MF 148 in reply to John in NZ, 11-15-2002 22:28:31
John,
see>Link
for>Link info on the 148
and>Link
for>Link the 135
On a similar vein I have been looking for a shop manual for the 148 but cannot find any refererence to one.
Is the 135 manual applicable to the 148
Cheers
R A McKay
10-02-2003 09:23:45
 Re: Re: MF 35 v MF 148 in reply to bg, 11-16-2002 16:45:18
THE MF 35X is similar to the MF 135. The MF 148 is based on the MF 135. It differs in the following ways (i)an 8 inch spacer in the gearbox
(ii) 8 speed gears althrough late 70's MF 135 also had this feature (iii) larger tyres front and back give it higher clearance (iv) cat 1 and cat 2 arms (again late 70's MF 135 had this feature),(v) the 148 has a AD3.152S engine which developed 47hp (DIN) to the MF 135's AD3.152 which produced 45hp (DIN) (vi) due to the spacer, the larger tyres and the larger arms it is 11 inches longer overall hence it turning circle is larger.
