Guages
RRamey
11-15-2002 12:15:19
I have a 135 massey that won't register the fuel and amperes gauages. Any suggestions would be appreciated.
Tom (OK)
11-15-2002 20:06:59
 Re: Guages in reply to RRamey, 11-15-2002 12:15:19
I have a MF 2135 on which the amperage and fuel gauges were screwey. It also wasn't charging the battery, so I had the generator rebuilt. I'm not sure if it's charging, but the ammeter still doesn't work, so I'll probably end up replacing the voltage regulator. You should be able to hook up a little nine-volt battery to the back of the meter to see if IT works. That should also work for the fuel gauge. All I did for it was to wiggle the wires and it started working.
