MF-85 Three point problem
Scott Fred
11-12-2002 11:04:02
I purchased a MF-85 tractor from a neighbor that had not been used in the last 20 years due to engine problems. I got it running then noticed the three point would not work. I took the top cover off and found the lift piston was stuck. I installed the new parts I needed, then found out the only way I can get the three point to work is by using the number one auxiliary valve. Why won't the hydralever operate the three point? The pump operates external cyclinders fine, so I figure either my two spool valves are not set right or something is wrong with the valves on the pump for the three point. Any help would be greatly appreciated.
dave
11-12-2002 20:41:01
 Re: MF-85 Three point problem in reply to Scott Fred, 11-12-2002 11:04:02
on my 165 i have the inside spool locked back to make the 3 point work with the draft lever while plowing.
Luke Stricker
12-05-2002 05:40:55
 Re: Re: MF-85 Three point problem in reply to dave, 11-12-2002 20:41:01
There might be a valve on the top of the transmission between your legs when sitting on the seat. Screw it out and it should work with out holding the lever back. Luke
