Massey Ferguson 135 Diesel
Stuck in 4th Gear -- Help!!
Sherry
11-11-2002 07:43:40
Hey All! Our Massey Ferguson 135 Diesel is stuck in 4th gear! Need some guidance on getting it into the other gears .... desparately need reverse for our post auger. Anyone, know anything about the transmission?
Scott
11-12-2002 11:48:19
 Re: Massey Ferguson 135 Diesel - Stuck in 4th Gear -- Help!! in reply to Sherry, 11-11-2002 07:43:40
Mine does it all the time. Usually comes from trying to slam it in gear before you have come to a complete stop, or trying to stick it in the wrong place. Usually gets the gear shifter between gears.
There is a hex-head filler cap just beside the bottom of the shifter that provides access to the transmission. Usually you can see the shift collar just inside the trans case. With mine, a big screwdriver or a small pry bar will unlock it pretty easily just by sliding the collar towards the front of the tractor.
Hope this helps.
Michael R. Parsons
12-17-2005 12:35:37
 Re: Re: Massey Ferguson 135 Diesel - Stuck in 4th in reply to Scott, 11-12-2002 11:48:19
Just wanted to say, "THANKS", my 135 locked up in the snow the other day, been dreading the worst possible scenerio of splitting the case and rebuilding the transmission and came across your post. You Sir are a life-saver!!!!
Mike Parsons
Yellow Springs, OH
IMJMAC
11-11-2002 16:03:44
GO TO BIG DEANS WEB SITE AND DOWNLOAD THE INSTRUCTIONS THERE ON HOW TO UNSTICK YOUR TRANNY. I JUST HAD TO DO MINE AGAIN LAST WEEK. IT'S REAL SIMPLE TO DO, TAKES ABOUT FIVE MINUTES.
