MF 245 losing power
Louie
11-11-2002 06:37:42
I have a MF 245 with 1,200 hours, it is a 1978 model and it has been used for logging and bush hogging. I live in Louisiana and when bush hogging an old pasture with bahaia hay, which is knee high, the tractor is beginnig to bog down when I pass over an old garden spot. The hay is extremely thick in this spot. I have a six speed tractor and run it in low third gear at 1,250 rpm which is what the tachometer reading lines the PTO to be used at. I am going to take it to a tractor diesel mechanic and ask him to do a compression test. Any suggestions? What should I watch out for?
Tom-TX
11-12-2002 07:55:45
 Re: MF 245 losing power in reply to Louie, 11-11-2002 06:37:42
Try sharpening your blades on the bush hog. Try pulling something else to check the tractor. Take to dealer and have him put on dyno.
Scott from Pa.
11-11-2002 15:42:20
Replace fuel filters is the beginning I would start at. Third gear sounds a littler fast for tha 135 in that thick of grass. How big is your hog?
Louie
11-12-2002 05:20:36
 Re: Re: MF 245 losing power in reply to Scott from Pa., 11-11-2002 15:42:20
I am pullin a 6 ft bush hog in low third gear. I have 25 acres of pasture to cut. I believe all filters are clean.
Bill in TN
11-11-2002 13:24:48
Try using a lower gear. 1250 rpm sounds slow to me. Good luck.
