Oil pan removal on MH 33
REGIER
11-11-2002 04:55:39
I have all the bolts out that I can see, but the oil pan still seems to be holding on between the engine and the clutch (but there is very little room can't get a good veiw.) do i have to unbolt the clutch and pull the engine ahead to remove what ever is holding the pan on.
need help Regier
missing two
11-11-2002 17:56:42
 Re: Oil pan removal on MH 33 in reply to REGIER, 11-11-2002 04:55:39
If its like the 44 there are two short bolts that hold it horizontally
C. T. in Oklahoma
11-11-2002 18:59:36
 Re: Re: Oil pan removal on MH 33 in reply to missing two, 11-11-2002 17:56:42
I have a MF35 and it has two horizontal bolts also. Probably doesn't make any difference, but mine is a Perkins 3 Cyl diesel. I would bet that is the problem.
C. T.
