MF 1155 wont start
Robbie
11-09-2002 15:53:04
I found a 1155 that has been sitting for about five years and in that time the farmer has taken the batteries and used them on another tractor and he said all it needed was two batteries and it should start, I installed two batteries and got no fire, whats the problem?
Earl
11-10-2002 16:24:03
 Re: MF 1155 wont start in reply to Robbie, 11-09-2002 15:53:04
Make sure you push the excess fuel button on the pump to allow more fuel to start it. Without that, it probably won't start. The button is on the right side of the fuel pump. It takes a lot of fuel to get a V-8 to start. It does mine, anyway.
TOM in FL
11-09-2002 21:04:32
Make sure the fuel supply is unrestricted and drain any old fuel and put in new. Make sure the fuel pump is working properly and that the injector pump and injectors are bled out. If it has an electric fuel cutoff, make sure it is getting power. If so, unscrew it and make sure the plunger in it is moving freely. Also check to see if any critters have set up housekeeping in the air filter. After all this, it starts getting expensive.
