Need help priming oil pump
jim (ky)
11-09-2002 05:17:19
Is there any way i can prime the oil pump on a z129 to-30 rebuilt the engine and cranked it with the starter with plugs out to build oil pressure and not getting no oil at all checked at guage and filter. Thanks for your help. jim
Bob in CA
11-09-2002 17:22:30
 Re: need help priming oil pump in reply to jim (ky), 11-09-2002 05:17:19
Jim,
In the past, I have removed the oil pressure line and fitting from the block. I then put a fitting in the block that accepts a 3/16" hose. I connect a hose to that fitting and the other end to a pump type oil can and then pump about a quart into the engine. This will fill the oil filter and then the oil pump. Once you get some oil into the pump it should then be able to pump on it's own.
Bob
Thanks BOB
11-10-2002 15:22:24
 Re: Re: need help priming oil pump in reply to Bob in CA, 11-09-2002 17:22:30
