Massey Ferguson Super 90
John Deere Man
11-04-2002 21:51:10
Back home on the farm we have a MF Super 90. Can't find much info on them,I have searched the web and nothing shows up. Would like to talk to other owners, cause last time i drove it, i had a hard time shifting it, our mf 135's are the same way. Do all fergusons from that era have doggy transmissions? Would like to know the hp specifications of the super 90, and how many were produced. Any help is much appreciated. Thank you.
John Deere Man
11-05-2002 20:37:01
 Re: Massey Ferguson Super 90 in reply to John Deere Man, 11-04-2002 21:51:10
Thank you all for your help. Our MF super 90 does have the multi-power transmission. I did not know that you have to downshift the multipower lever to shift gears. I was never told to do that, and it will be of great assistance when I use the MF again. It used to be one of our primary tractors till we quit farming, now we just bale hay with it. Im currently away at college, and I miss my tractors, parents, and dog very much. As soon as I find some free time, I would like to paint her up. She sure would look pretty fixed up, they have to be the nicest looking tractors of that era. I was using her last weekend to pull a 10 ft case disk, it sure is a good combination. Got a row of grey and green tractors to fix up before i get to the 90 though. Not many mf tractors here in Northeast New Jersey at all, never seen another super 90. We bought her new along with two 135's to farm with, and we still use them today. We still have a couple of jd a's and a b that we purchased new and still use also. Can't beat those old tractors, our 6605 and 5410 jd probably wont last half as long as those older tractors did. I appreciate all your help, and wish you good luck with all your projects. Thank you
Joe Ferguson
11-06-2002 07:07:50
 Re: Re: Massey Ferguson Super 90 in reply to John Deere Man, 11-05-2002 20:37:01
Hi
If you still have your operator's manual
see the multi-power section you will find
informations already given.
Good luck
Joe Ferguson
Fred Wolfe
11-05-2002 17:18:55
I have a super 90 diesel,85 gas and 97 diesel. My 90 is in tractor photos. The 85 and 90 have a transmission brake.The reason for hard shifting.I have owned the 85 since it was new. Also collect Massey Harris and MF tractors. I have a super 90 owners manual.
John Deere Man
11-05-2002 20:40:52
 Re: Re: Massey Ferguson Super 90 in reply to Fred Wolfe, 11-05-2002 17:18:55
Is that your MF super 90 with the narrow front? If it is, it sure is a fine machine. I currently have it set as the backround on my computer. Thank you for your help.
Fred
11-06-2002 11:42:02
 Re: Re: Re: Massey Ferguson Super 90 in reply to John Deere Man, 11-05-2002 20:40:52
That is my super 90. Thanks
Joe Ferguson
11-05-2002 08:00:45
HI
If there is multi power on your tractors
it must be shifted to "LOW" before atempting
to shift transmission especially down/up-hill..
reason too long to explain here.
If there is no multi power..just lift the rubber
boots at base of levers you may find rust accumulation which may be treated with usual products.
Good luck
Joe Ferguson
Joe Ferguson (follow-up)
11-05-2002 08:20:48
 Re: Re: Massey Ferguson Super 90 in reply to Joe Ferguson, 11-05-2002 08:00:45
You can find these informations left of
your screen "Serial numbers"
MF-90 & Super-90
Year Starting Serial Number 1962..... ..... .810000 1963..... ..... .813170 1964..... ..... .816113 1965..... ..... .819342
Good luck
Joe Ferguson
bill
11-05-2002 05:40:33
the s90 is all MF not any part MM
James, UK
11-06-2002 00:34:14
 Re: Re: Massey Ferguson Super 90 in reply to bill, 11-05-2002 05:40:33
Bill,
I had another look through the 'archives' at home. It was a Super 95 I had seen, not a 90, and that was originally an MM GBD that had been re-badged and re-styled specifically for the North American market.
Not all MFs are all MF after all!
James, UK
11-05-2002 05:08:56
I could be wrong, but I'm sure I saw a photo of one of these recently - bow-shaped front axle and not straight?
If that's the case, then I think I also read that the Super 90 was a re-badged/re-tinned Minneapolis Moline brought out in a bit of a hurry by MF to fill a gap.
IF that's the case, then MM owners may be able to help you out.
Sorry I can't be more precise - I don't think I ever seen one over here.
Steve
11-05-2002 04:46:47
I own a 1964 MF90 that has multipower tranny, and this tractor will out pull my Ford 5000 diesel. The horsepower depends on wether it is a gas model or a diesel. My tractor has the continental gas engine, that I believe to be a 68 HP gas engine. I'm not sure what the perkins diesel engine is rated for. My MF90 is sluggish to shift when it is cold, or when the oil is low. The multipower is a hydrualic clutch, and when the hydrualics are slow, the clutch is slow. I'm no mechanic, or expert by any means, but I do own one, and play with it from time to time. I know this is the place to learn, the people on this board are very good at answering questions and helping out.
P.S. I have a couple shop manuals on the tractor if that would help.
jiml
11-05-2002 12:42:48
 Re: Re: Massey Ferguson Super 90 in reply to Steve, 11-05-2002 04:46:47
I too have a Super 90, mine is diesel, with supposedly 68.53 HP. It has a Perkins A300 engine of 302 CI. I have recently purchased this tractor to use around my place. I have replaced the brake disks and most of the bearings in the rear axles. I have replaced the seat, steering wheel,instruments and replaced the generator with an alternator. I would like to obtain a Massey Ferguson shop manual or a copy of one. I have a copy of the MF operator's manual and parts list, and a copy of the I & T repair manual.
