REAL M H PROBLEMS HELP!!!!!!!!!!!!!
DANN
11-02-2002 10:51:13
GOT THE ENGINE OUT OF MH 30, SUPPOSED TO BE A CONTINENTAL, HAD NUMBER GROUND OFF AFTER GETTTING IT OUT AND CLEANED UP FOUND ON GOVERNOR HOUSING HERCULES ENGINE COMPANY BORE IS AROUND 3-7/8"
STROKE IS AROUND 4-3/8 0R 4-1/2"I WAS TOLD POSSIBLE A JX4D-2 OR JX4D-3???? ANY BODY KNOW ANY THING ABOUT THESES ENGINES? WHERE DO I FIND PARTS? HAS 19 STUDDS HOLDING HEAD DOWN, HAS A VICTOR HEAD GASKET PART #3034 AND ITS A FLAT HEAD 4 CLYINDER WHAT IS IT????? THANKS DANN
JERRY ON Long Island , N.Y
11-06-2002 16:16:25
 Re: REAL M H PROBLEMS HELP!!!!!!!!!!!!! in reply to DANN, 11-02-2002 10:51:13
Go on www.google.com , then WAUKESHA MFG. LOCATION THEN CONTACT FOR INFO.HTH JERRY
Larry from Maryland
11-02-2002 15:17:11
jx4c is 33/4 pistons,jx4d is 4 inch pistons with 4 1/4 stroke.Parts?
Eardrum!
11-02-2002 12:58:11
Why do you SHOUT AT US?
plus, they are not problems, just work!
