TO35 Deluxe's Lights Dont work!!
to35deluxeman
10-29-2002 11:27:48
Hey guys the lights have worked in the past, but have been fixed many times then after a while they dont work, how can i fix the lights myself or is there a good dealer around to fix this prob.....
No rush, the 35 deluxe isnt going to be used much this winter, its just.....it'd be nice to have them working....
Email me for all youre answers or post them here
ps-SN is SGM 187042!!!
Scott from Pa.
11-02-2002 04:31:38
 Re: TO35 Deluxe's Lights Dont work!! in reply to to35deluxeman, 10-29-2002 11:27:48
Like Don says check all the mechanical parts of your lights,i.e. switch, bulbs, etc. and make sure they are good. Every experience I have had, and I do mean 99.9% of the time,it is a bad ground somewhere in your system. Make sure. Scott
Don-WI
10-29-2002 20:16:10
I'm not familiar with headlights on a to35, but I recently fixed the headlights on my 165. First things to check are if the bulbs are good,if the switch is good, the wires and if you have a good ground. I replaced my wires with a 16 gauge wire. Also if there is a fuse in the line. If not, put one in, you can buy either a panel mount that will mount on the dash, or an inline that just gets spliced into the wire under the hood. I use either a 20 or 30 amp fuse, I cant remember but I think it's a 30. I have 4 forward and 1 rear work light. I imagine a to35 only has 2 bulbs in front so a 20 should work just fine.
Don
