50c backhoe
Paul
10-27-2002 13:04:49
The fuel line from the filter to the injecton pump is leaking had it apart theres a rubber washer in there. Anybody got an idea how to stop the leak?
Big Dean
10-27-2002 16:30:14
 Re: 50c backhoe in reply to Paul, 10-27-2002 13:04:49
Paul probaly the rubber sleeve stayed in the connection when you remove the line they usually do. Remove the old sleeve you may have to pick it out with something like an icepick. Install the new rubber sleeve onto the line stick the line in the connection & work the rubber sleeve down till you can start the line nut. It will be a very tight fit but it will go in enough you can start the nut. Do not over tighten the nut just enough to stop it from leaking. Check the line just above where the sleeve fits for a crack If they are over tighten they will sometimes cause the line to crack there.
Floyd
10-27-2002 13:36:46
Replace rubber olive and tighten it
