MF 240 Stats
John in OH
10-26-2002 15:35:21
I'm looking at a MF240, s/n 2773-N13077, circa 1980s, with the 3 cylinder diesel engine. Several questions for you of great wisdom - why isn't the MF240 included in the serial number lists of this website? What is the actual year of production? What is the rated HP of this tractor? And last, this particular tractor has no provisions for remote hydraulics. Can this feature be added at a reasonable cost or should I keep looking for another tractor? I'm looking at this as a working tractor, not for collection.
Thanks, John in OH
eVictor54
11-01-2002 21:26:38
 Re: MF 240 Stats in reply to John in OH, 10-26-2002 15:35:21
John,
I also have been looking for MF 240 serial numbers. It seems they must be some sort of secret. If you find them let me know.
I have had a 1996? MF 240 for 3 years and am highly pleased. I use it primarly for bush-hoging. The engine and hydrolics are idealy suited for a six foot Bush Hog Squealer. I cut heavy fescue and weeds higher than the cowling and the governor barely cuts in. In 850 hours of use I have never heard the engine miss a beat.
Fuel usage is unbelieveable. It will run forever on a tank of fuel.
Dave
11-03-2002 10:19:18
 Re: Re: MF 240 Stats in reply to eVictor54, 11-01-2002 21:26:38
John, I also own a MF 240. I bought it new in 1988 and it has 1050hrs on it. This is one of the best tractors I have ever owned, and I have had many. Other than regular maintenance, I have not had to fix anything. I think the reason they are not included in the S N list is because they are made in Great Britain. Its no big deal to add remotes, As stated earlier its a simple plate change. Goodluck, D
Ian
10-21-2004 02:27:03
 Re: Re: Re: MF 240 Stats in reply to Dave, 11-03-2002 10:19:18
i am thinking of buying a new MF240 as a scraping tractor could any one tell me what the gear speeds are like for this job.
MF 240
10-28-2002 04:26:37
I think you should buy this tractor. The MF 240 are wery good tractors, I have one 1984 MF 240 with 6000 hrs on it. It runs well and there is no problem getting it running even if there is -15�C.
Hawk
10-26-2002 16:43:44
You have a 1988, pto 41hp, engine 46hp, 29 drawbar. If it's like my 245, there's a small plate under the seat on the right forward of the seat that can be removed and a diverter valve added to steal 4 gpm from the 3 point. Of coarse for about $450.00 and some fabrication on your own, you can add a front pump driven from the crank pully. Makes the hydraulics move faster.
