Carb. adjustment on MH 81 ?
luc van sinay
10-23-2002 15:12:01
Hello,
I took off today to clean my carb(Marvell Schebbler) on my MH 81.
As i screw everything out to clean i lost carb settings.
Can someone tell me what the initial settings are of needle and mixing screw so i know where to start and making final adjustment with running engine.
Thanks for your help and have a nice day.
Luc
mark
10-23-2002 18:13:19
 Re: carb. adjustment on MH 81 ? in reply to luc van sinay, 10-23-2002 15:12:01
your float needle should not have changed unless you bent the float arm, try 1 1/2 to 2 turns on your idle and fast idle (load) screws and then go from there.
luc van sinay
10-23-2002 23:27:31
 Re: Re: carb. adjustment on MH 81 ? in reply to mark, 10-23-2002 18:13:19
Thanks for your help.
Luc
