Spin on filter adapters for 23C
Larry Counts
10-22-2002 14:40:25
I'm having a hard time stopping fuel leaks in my 1959 FE35. The primary & secondary fuel filters, are weeping fuel. It looks like the leak is coming from the filter body, & tightening bolt on the bottom. I replaced all of the copper washers, gaskets,& O rings. I did everything else I could think of. Is there an adapter for using the modern spin on filters? Is the fuel line that supply�s fuel to the thermostart necessary. I'm getting a small leak from there also. The Thermostart is missing & the hole in the manifold is plugged. Can I remove the fuel supply line to the thermostart reservoir without concern? Would I benefit from installing a Glow Plug in the intake manifold where the thermostart use to be?
Thanks
David
10-24-2002 13:10:30
 Re: Spin on filter adapters for 23C in reply to Larry Counts, 10-22-2002 14:40:25
I have an FE35 with 23c. Don't know about filters. Did you try putting silicon on the leaky bits before assembling them? They'd probably need to be clean first.
The thermostart fuel line isn't needed unless you have the thermostart fitted. It only supplies fuel to let the thermostart operate when heating the engine before starting. 23c's are hard to start from cold and always seem to need heated. How do you get yours going without the thermostart? Do you have to use aerostart/ether or something?
