I found out the truth...RE.Rearwheels
Dan
10-20-2002 08:54:34
The rear rims off a styled JD D do fit on the rear hubs of a MH44 GS( std. fr. axle.) Tried it on Sat. Fit like a glove.
off the land
10-20-2002 12:01:19
 Re: I found out the truth...RE.Rearwheels in reply to Dan, 10-20-2002 08:54:34
Dan,
Thanks for the report on your hard work swap. How
do we reference it for future generations, since
the MH 44 was mankind's greatest achievement? Seriously, good info, but hard to remember. The
recent post of the frustrated owner of a new
generic import pressed steel, 9 bolt rim, comes to
mind. The opening was smaller than the M-H cast
hub shoulder, a lot of integrity lost grinding the rim opening, probably crack if worked on a
hillside. Glad your labors paid off.
Alberta Mike
10-20-2002 14:35:42
 Re: Re: I found out the truth...RE.Rearwheels in reply to off the land, 10-20-2002 12:01:19
I know there are Massey fans out there but mankinds greatest achievement? You "might" be stretching it a bit. I would agree with you had you said the Essex Tri-Directional, now THERE was a TRACTOR !!!
Dan
10-20-2002 19:55:38
 Re: Re: Re: I found out the truth...RE.Rearwheels in reply to Alberta Mike, 10-20-2002 14:35:42
The thing is when I posted the question of the wheels interchanging from a D to a 44, most replies seem to indicate they would not fit.Some even said a rim is as different as a finger print,but I subscribe to the believe that most rims were made by Goodyear or a handfull of other companies,but its all academic now,I got hold of a complete 44 parts tractor with good rear rims and the differenceis the D rim has an anti-slip block whereas the 44 rim has 2 bars to prevent slipping.
