MF 165
Jalinn
10-18-2002 10:38:55
I bought a "71" MF 165 about two months ago. I really like this tractor( thanks for the help Big Dean ). My throttle control seems a little loose. Is there any way to tighten it so that it holds its position better?
Lynch
11-06-2002 16:54:34
 Re: MF 165 in reply to Jalinn, 10-18-2002 10:38:55
The throttle control lever is fitted with a spring-loaded friction washer, which holds the throttle lever at the desired setting. After considerable usage, the washer may become worn, allowing the throttle control lever to "creep" from the desired setting. To compensate for wear, tighten the two clamp nuts on the friction washer assembly, compressing the tension spring, until the throttle lever ceases to creep. THAT'S RIGHT OUT OF THE MANUAL.
