Tire chains, size?
Murray
10-14-2002 17:16:17
I am attempting to modify a set of chains for the MF 135. The tire size is 13.6 x 28. If possible could someone give me the proper width and length for these chains. As always appreciate this information. Cheers. Murray
Jack in NB
10-16-2002 10:54:12
 Re: Tire chains, size? in reply to Murray, 10-14-2002 17:16:17
Hi Murray -
20 to 22" cross chains and 110" or so (times 4) of side chain will get you going.
You can put the cross chains every 4 links for good results, or every 2 links for really heavy duty work. The cross chains don't have to be evenly spaced to work well - they just look more professional. They'll bunch up when you start using them.
Cross chains every two links get heavy as the devil to handle.
You can splice the side chains with anything to lengthen or join odd lengths - rod the same size as the chain (or the next size up) works well. There's not a lot of strain on them.
Murray
10-17-2002 03:57:10
 Re: Re: Tire chains, size? in reply to Jack in NB, 10-16-2002 10:54:12
Thanks Jack in N.B. for the information on the size of chains. Just one question, what did you mean by 110" or so (times 4). I did inherit a set of badly beat up chains when I purchased an 8n a few years ago, so plans are to rebuild. By the way what part of N.B. do you reside? cheers, Murray
Jack in NB
10-17-2002 14:32:55
 Re: Re: Re: Tire chains, size? in reply to Murray, 10-17-2002 03:57:10
Hi Murray -
Each side chain will be about 110" long, more or less, depending on the overall length of the cross chains. Longer cross chains will slide further around the tire, making the side chains closer to the center of the wheel, smaller diamerter, therefore shorter. And you will have 4 side chains - two for each wheel. You can lengthen the 8N side chains as required with a splice made in the shop from a piece of rod shaped like a link and welded, using extra chain from wherever.
I'm in Fredericton.
Jack in NB
10-18-2002 02:35:40
 Re: Re: Re: Re: Tire chains, size? in reply to Jack in NB, 10-17-2002 14:32:55
Hi again Murray -
Your 8N cross chains will probably be shorter because of the smaller tire on the 8N. The side chains will have to be lengthened - possibly 12 to 18". You can leave a gap with no cross chains in the extentions, with a bit of loss in traction, but it would be better to add one or two more cross chains.
Murray
10-18-2002 04:24:27
 Re: Re: Re: Re: Re: Tire chains, size? in reply to Jack in NB, 10-18-2002 02:35:40
Hi Jack, The set of chains that came with the 8n, appear to be almost too wide for the MF, so thay can be shortened. ( I did purchase one chain, for one wheel) at an auction for $1.00. so do have some extra chain to work with. I live in the city, (Dartmouth) and keep the MF in the Annapolis valley 160 kl away, will wait until next week to start redesigning the chains. I am attempting to get hydraulic pressure from the tractor MF135 to a wood splitter and a cord wood saw. Apparently there is not enough pressure from the valve that fits on the top of transmission to supply the hydraulic pressure to work these two pieces of equipment. What are the other cheap ways to supply the pressure from a power take off with some type of pump? I have no knowledge in the area. Could a good used one be purchased? Thanks, Murray
