Massey Harris Special Serial Number
Dave Golden
10-07-2002 19:56:44
I scanned all over this Massey Harris 44 special. I cannot find any numbers on this tractor that start with 44 then a letter then the number. I have numbers off the transmiision cover, and the numbers under the frame below the side rails,and I also found a number on the hydraulic cylinder mount on the right hand side of the seat, its stamped MF and then under that is the word "canada" then under canada a long number that I believe ends in M1 !!! but those dont tell me the serial number, any other other suggestions ? Please send replys to [email protected]
Bruce Colbourne
10-08-2002 08:15:31
 Re: Massey Harris Special Serial Number in reply to Dave Golden, 10-07-2002 19:56:44
The serial number will be stamped into the top off the rear-end housing behind the pto shifter cover.You may have to clean off some paint to find it.Hope this helps you.
Dave Golden
10-10-2002 13:47:13
 Re: Re: Massey Harris Special Serial Number in reply to Bruce Colbourne, 10-08-2002 08:15:31
I finally found the serial number on my Massey Hareris 44 Special, and would like to thank everyone who offered advice.. It was located near the PTO shifter, and I also had to do some wire brushing to find it.. Thanks, Dave Golden (Stoystown, Pa)
joey eggnatz
12-02-2003 19:53:35
 Re: Re: Re: Massey Harris Special Serial Number in reply to Dave Golden, 10-10-2002 13:47:13
i have a transmission that i would like to sell, but do not know what kind of transmission it is. All i have is the serial number, which is PVAB XS4P-CP and 932708. where can i use this to find out What type of car this transmission belongs to?
