Massey 55 ??
usafarmer
10-05-2002 18:15:23
I have been offered a Massey 55 Diesel Western Special. Is there such a tractor and are they collectable? Thanks John
Bruce Colbourne
10-17-2002 21:01:14
 Re: Massey 55 ?? in reply to usafarmer, 10-05-2002 18:15:23
Massey-Harris built a model 55 DISH [Diesel Western][DSW].They were built from 1951 to 1954.Serial numbers start at 1,001 and go to 15,299.The following are the different models of the 55-MH.55-Gas-Standard,55D-Riceland&Hillside,55 High Altitude,55K-Standard,55[Gas Western],55Standard,55[Diesel Western],55G[Riceland&Hillside],55K[Riceland&Hillside].
marty g.
10-10-2002 08:57:51
Do you have a picture? I've never seen one of those in our area.
Wayne
10-06-2002 19:17:20
I have a few massey 55,and 555.The western special had I believe 26 inch rear tires and a wider arched front axle,I believe they were hand clutch as well.I have an original factory manual for 55 western special cause I hope to find one one day.They are fairly rare,and usually reasonably priced.
good luck
Wayne
BC,Canada
Alberta Mike
10-05-2002 20:23:04
I've never heard the term "western special", I suppose it is another term for regular wide-front fixed wheels front and back. As far as collectability, I would think it depends on where you live. Up here there seem to be a lot of the 55's (not nearly as many as there are 44's) so they aren't rare, but in some places they probably are. I think some of the guys want them for tractor pulling competitions. Keep in mind that's apretty big tractor, as big as they got in that era and working on the big stuff isn't easy unless you're set up for it. Hope the rear rubber is decent, I wouldn't want to put tires on that brute.
