MF-40 ground ground speed position doesn't work.
Terry Stoen
10-03-2002 08:36:55
I have a 1971 Mf-40,the ground speed position on the pto selector lever doesn't work,when I run my rotary mower I would use the ground speed position on my pto,I have an overrunning clutch mounted on my pto.I've looked in the shop manual and all that it shows me is how to change the pto bearing,I've taken the side cover by the selector lever off and couldn't see anything wrong with the shaft.I tried running the rotary mower in the engine speed position,I had a gear in the rotary mower's gear box strip the teeth off the gear,it seems that the engine speed position runs the pto to fast for the mower.Could someone explain what could be wrong with the ground speed gear,and what I'll need to do to fix the problem.
Thanks Terry Stoen
Gary F
10-03-2002 12:58:23
 Re: MF-40 ground ground speed position doesn't work. in reply to Terry Stoen, 10-03-2002 08:36:55
If this is MF 40 industrial with instant reverse trans you do not have "ground speed". Also you should be using engine speed to run you rotary moweras ground speed would be to slow.
Gary
