John. I recently brought a MF 35 back to life. I learned a lot about the Ferguson lift system from Big Deans website, TractorSmart.com, and the owner's and shop manuels.-Start by identifying whether your pump has a filter or screen that is more than likely mucked up solid (you will have to remove the left side inspection cover to access it ). Clean that out first and trouble shoot from there. If you don't do this, you're shooting yourself in the foot . -Next, remove the right side inspection cover and see what the vertical contol lever is doing when you move the lever on the lift quadrant. It should move a control valve roller back about 1/2 to 3/4 inch. -Take a pressure reading with a direct reading guage from the fitting on the transfer plate (located on the right front corner of the lift cover. -Now you're ready to e-mail Big Dean and get the straight skinny on how you should tackle the problem. Enjoy the opportunity to get to know Harry Ferguson up close and personal! Jim
