Parts advice for a 444 M.H.
Mike D.
09-29-2002 19:46:51
The ignition relay clicks whenever we turn the key to start the tractor. The tractor has been sitting for 6 weeks or so. Tried several barreries.
Any ideas? Where can I buy a new relay if thats the problem? Mike
marlowe
09-30-2002 18:47:11
 Re: parts advice for a 444 M.H. in reply to Mike D., 09-29-2002 19:46:51
i dont recall any relay on a 444 or did you mean the starter cellunoid?? not the right spelling but hope you know what i mean. if it is they are the some as the old ford auto ones.use on trucks and autos just go to napa or other parts store eaven walmart has them
Mike D.
10-01-2002 05:53:43
 Re: Re: parts advice for a 444 M.H. in reply to marlowe, 09-30-2002 18:47:11
Hello Marlowe, The relay is on the back of the engine. It has the wire from the switch. A wire to the battery, and a wire to the solenoid on the starter. I'll check out Napa for it. Never thought that our local Napa would have it because of its age and rarity around here. Not any 444s
anywhere around these parts that I've seen. On another note: thanks for the advice on the alternator question for the Case 450. Mike
Alberta Mike
09-30-2002 06:27:10
Remove the battery cables and clean both ends totally free of all crud, corosion and color until they are a nice uniform shiny color. Emery cloth works well then a stiff clean wire brushing. Especially the ends at the battery terminals (and the battery terminals too). Reinstall everything nice and tight and I think your problem will be solved.
Mike D.
10-01-2002 05:59:28
 Re: Re: parts advice for a 444 M.H. in reply to Alberta Mike, 09-30-2002 06:27:10
Hello Alberta Mike, Bet it is getting cooler in your neck of the woods. Thanks for reminding me to keep the terminals and clamps cleaned up. I did clean the battery clamps, and traded another battery. I'll clean up the terminals on the relay next. It looks clean now, but that corrosion is some sneaky stuff. Thanks again-
