MF 235 Steering Problem?
Jay
09-27-2002 19:11:21
MF235 with factory powersteering,problem is when you turn the wheel it take's a couple of turn's before you start to turn.The steering wheel allso back's out or rises out of the housing.Any help,please!Thank you,Jay
David Mullins
11-20-2002 06:33:46
 Re: MF 235 Steering Problem? in reply to Jay, 09-27-2002 19:11:21
I bought a 1975 model massey 235 in 97, it had a power steering leak around the steering wheel shaft. I had it repaired and it didn't leak for a couple of years. It's leaking again. I know about the problems of the 235 power steering now.I need to know if it is someone with some knowledge on correcting it. thank you
JohnnyB
09-28-2002 17:49:50
No, don't put a manual box on it. It can be fixed with a little effort. I don't know much about the 235 but have run massey for 20+ years. My 180 done the same thing early this spring, the coupler that connects the steering shaft to the hydraulic hand pump lost its grip, once I removed all the sheet metal from around the steering it was an easy fix, a new bolt. If you dont have a full set of manuals, get them and study up then go to work.
Help,somebody,anybody...Please!
09-28-2002 16:53:52
Thinking about putting a manual steering box on it,can it be done?? jay
Why ruin tractor
09-29-2002 06:50:46
 Re: Re: MF 235 Steering Problem? in reply to Help,somebody,anybody...Please!, 09-28-2002 16:53:52
Get three manuals: Operator's, Repair, Parts. Then fix it right.
