Hyd. lift problem
Clayton
09-27-2002 09:48:05
the lift on a to35 does not work. I put a peessure guage on it and get a reading that moves the needle between 200 and 900. Is there something in the pump i should look for that could be the problem or is there something else wrong? The stem pipe doesn't seem to be leaking. All info. will be appreciated. THANKS Clayton
Boma E. Trollinger
02-13-2003 09:10:33
 Re: hyd. lift problem in reply to Clayton, 09-27-2002 09:48:05
I've got m-f fork lift<>was use ing to load a pu tk. on tra. and all at once it didn't want to pick up..I speeded up motor an it quit lifting altogather..It has 3 valves side by side.. the other 2 work- the tilt an the side to side..<> there is hyd. fld. comeing out of a little {looks like] releaf port under the dash <>could you give me any info on what might be wrong or what happened thank you very much.. respond to Boma<> thank you<> asap
