MF35 valve train
garvas
09-26-2002 06:46:22
I have a 35 which has considerable upper valve noise. Before I tear into this, what am I getting myself into? Not a bad mechanic just not as good as I used to be...
Fred OH
09-26-2002 09:27:36
 Re: MF35 valve train in reply to garvas, 09-26-2002 06:46:22
Not anything unusual about it...the rocker arms and shaft do wear...and more so if it doesn't get correct oiling. check the ends of the shaft if you have a Continental engine...they have a cork stuffed in there with a cotterpin holding it in. If it isn't in place, the oil will run out there instead of oiling things in the valve train. Also, if the valves get too loose...the little caps on the ends of the valves could fly off making a lot more clearance and more noise. Just standard hand wrenches to do this one...unless something drastic is wrong. L8R....Fred OH
