Mf 35 Perkins diesel air cleaner repla.
Peter
09-25-2002 19:38:30
The rear wall on my oil bath type air cleaner canister is rotted through. I suppose I can cut out the bad material and have new brazed in. Anyone have any ideas on either locating OEM cansiter or substitution of another cleaner? I calculated cfm at slightly less than 100. Have read pro's & con's on paper verses oil bath...an oil bath replacement is fine with me, maybe even preferred. Any opinions/suggestions on air cleaner theory also welcome. Many thanks!
WILL
09-28-2002 18:26:11
 Re: mf 35 Perkins diesel air cleaner repla. in reply to Peter, 09-25-2002 19:38:30
PETER I AM IN AND OF SALVAGE YARDS ALL THE TIME I LIVE IN SOUTH GA I BUY AND SELL USED EQ SOMETIMES THEY WILL GIVE YOU GOOD PRICE SOMETIMES THEY WANT GOLD CHECK WITH MORE THAN ONE YARD YOU MIGHT SAVE SOME OF THAT GOLD
Peter
09-30-2002 16:46:46
 Re: Re: mf 35 Perkins diesel air cleaner repla. in reply to WILL, 09-28-2002 18:26:11
Thanks Will. Saturday I went to vist a neighbor, taking the filter with me to compare to his tractor. Figured if I have to travel several hours to a yard, I might want to know ahead of time if parts are interchangable between various motor types and also other Massey models. Neighbor took the canister and said his brother could weld it easy. Heard this morning he nearly finished the job but ran out of gas (MIG). I weld with AC/DC stick, so I guess a neighborly MIG/TIG solution slipped right by me.
will
09-30-2002 19:56:34
 Re: Re: Re: mf 35 Perkins diesel air cleaner repla. in reply to Peter, 09-30-2002 16:46:46
THAT SOUNDS GOOD I KNOW IT DOES TO YOU SOMETIMES IT IS BETTER TO LET SOMEONE ELSE LOOK AT SOMETHING TWO HEADS ARE BETTER THAN ONE
will
09-26-2002 16:35:01
have you check with a salvage yard
Peter
09-26-2002 17:09:17
 Re: Re: mf 35 Perkins diesel air cleaner repla. in reply to will, 09-26-2002 16:35:01
Thanks Will, the MF supplier I normally deal with didn't have any luck but was able to give me the # of a salvage yard today. PS: I've some vacation time coming, just might walk through a yard (or two) if allowed. As a mechanical engineer I enjoy seeing how 'other folks' solved problems/arranged components/etc.
marty g.
09-26-2002 05:49:20
This is only my opininion, but there is probably a K&N filter that could be fitted in place of the oil bath. The K&N is reusable, washable cotton type element. You would only have to install it in line with the intake hose. This could be a temporary fix until you find an OEM replacement if that is your wish.
Peter
09-26-2002 15:43:33
 Re: Re: mf 35 Perkins diesel air cleaner repla. in reply to marty g., 09-26-2002 05:49:20
Thanks Marty. I was originally for a K & N but read a post somewhere that folks using them in Baja type environments experienced engine wear. One man's opinion....that's why I asked for the experience of ytmag members. I'll take another look.
SMOKEY
09-26-2002 00:50:23
Some Bareco parts are made in India but they seem to fit and be OK. There site lists parts diagrams for MF tractors which are very useful. Quite handy downunder.
Peter
09-26-2002 16:13:18
 Re: Re: mf 35 Perkins diesel air cleaner repla. in reply to SMOKEY, 09-26-2002 00:50:23
I am waiting for a reply from Barco on pricing and availability. A question I have yet to answer..The filter canister shown is cylindrical with an output pointing 45 degrees down. Research in my limited library of manuals seems to indicate that this style was used on the Z-134 Continental engine. I have a somewhat rectangular filter with a horizontal outlet at near the top. Would I have to adapt by using molded radiator hose or a fitting with 135 degree included angle? Again, feedback appreciated.
Tim (TX)
09-25-2002 20:03:20
Hello Peter, BARECO (and probably several other parts dealers on the internet) sells a new oil bath canister for your 35. They are out of Australia but now have a dealership in California. I have ordered a few hard-to-get parts from them for my 135 and was very pleased. I have listed a link below. Good luck, Tim
Peter
09-25-2002 20:08:33
 Re: Re: mf 35 Perkins diesel air cleaner repla. in reply to Tim (TX), 09-25-2002 20:03:20
Thanks Tim, will give it a try. Searching the internet didn't get me far but could be my 'search' skills need improvement.
