Mower setting
Neil
09-25-2002 18:21:00
I just bought an MF135 and am pretty green about tractors. Should I be using the Draft control or the position control when using a mower? I have the operating manual, but it doesn't address mowers. Also, should I be using a lead additive in the gas? Any advice would be appreciated.
gy3020
09-25-2002 19:09:31
 Re: mower setting in reply to Neil, 09-25-2002 18:21:00
Hey Neil,
I have a 70 model 135, welcome to the world of one of the most popular small tractors. Love mine! Pulls the haybine, rakes, square baler adn so on. As for lift on the mower, the draft control is used for plows and not for mowers, you need to use the position control for your mower work. Set the little stop wheel on the control to allow for going back to the same height with no guess work.
Draft control allows for constant depth of your plows when the front end rises or falls when working. I have never put anything in gas on mine but B-12 every now and then and mine has always done great. A word of caution, when mowing close to fences be carefull and don't turn away too quick or you can take out a post or two. You will get the hang of it when you get some time in the seat. Gary
