Looking for MF bushing
Jack in NB
01-24-2000 13:06:59
Local dealer can't get the bushing for the Multi-power input assembly. (same bush fits 35, 135, 65, 165, ....)
MF part 188 856 M1, or 511 825 M1. 1 39/64" x 1 3/4" , 3/4" long. Steel back, brass bushing surface.
There is a manufacturer in Chicago? McMaster? I lost my bookmark file a while back, and can't find a reference by searching.
Does anyone have a lead?
Gerald J.
01-24-2000 20:51:55
 Re: Looking for MF bushing in reply to Jack in NB, 01-24-2000 13:06:59
The original Garloc bushings probably had a thicker wall than Garloc makes now. McMaster-Carr is an industrial hardware store. Look on the internet for bearing companies. The rocker arm bushings have the same problem. I made some from solid bronze bushings to replace the steel backed Garloc bushings. I think Garloc has a web page too.
Gerald J.
ALAMO METAL SUPPLY
12-06-2000 12:43:30
 Re: Re: Looking for MF bushing in reply to Gerald J., 01-24-2000 20:51:55
WE STOCK MANY SIZES OF BUSHINGS, ALSO WE MANUFACTURE ANY SIZE BUSHING YOU WILL NEED. CALL (562) 626-0016
Marvin
01-24-2000 15:44:58
Jack, I think this link is the company you are referring to. Since you know the diminsions for the bushing any machine shop can make it for you from materials that may last longer than the original did. Heres the link. Good luck Link
Jack
01-25-2000 03:46:11
 Re: Re: Looking for MF bushing in reply to Marvin, 01-24-2000 15:44:58
Thank you, gentlemen - the link worked; haven't found Garloc, but will keep trying.
And may wind up making it, as you suggest, Gerald.
Jack
