MF-65 restoration
Rob C
09-21-2002 16:23:59
I have just gotten hold of a -59 mf-65. This is my
first tractor project. Any advise on what to look
for or lookout for?
MF-65 Guy
09-23-2002 15:19:54
 Re: MF-65 restoration in reply to Rob C, 09-21-2002 16:23:59
I am just finishing up a year-long total restoration of a MF-65 with a Continental gas engine. This was also my first tractor restoration. From my efforts, I can tell you what I should have done: First, make sure you have a complete shop manual and parts book. There are some tricky aspects of the dual clutch which should not be attempted blind.
Next, don't cut corners. My tractor reportedly had a recent engine job before I got it. However, the guy before me did not appear to have been very meticulous, causing lots of problems when I rebuilt it again.
My most serious problem was that the thrust bearing failed and the crankshaft bored its way into the block. This is apparently not uncommon with the MF-65 and is caused by an improperly adjusted clutch. Luckily, I was able to have the crankshaft welded and reground, but it was expensive!
Lastly, shop around for parts. I got many of my parts from a local Massey dealer only to find the same OEM part on the internet for less than half price.
Good Luck.
BOB UK
09-22-2002 12:31:20
Hi Rob
just to get you started click on SEARCH THIS SITE on the left of the screen and enter in MF65, there are 365 posting and replys on the MF65 i'm sure there are some very good posting that will help you get started, you can refine the search to just one question if there is one subject you need an answer on.
You own the one Tractor I would like to get as I have a TEA 20 and a FE 35 it would just finish the set.
good luck,
BOB UK
