Massey harris 44 diesel
robk
09-20-2002 21:49:10
I have recently bought a MH 44D.It has sat for years.It is complete,has power steering and 3 pt hitch.The sheet metal is good,just rusty. The man who worked for the owner {owner passed away last year} says the engine is a buda diesel.
Is this different from a continental?Or is it a model name?It is a 4 cylinder diesel,that is all I know about it. He also told me that I can't get parts to rebuild the engine anymore,is this true?Could an engine shop adapt other parts to make it work?I know nothing about massey harris,I have never even heard one running before.I would like to rebuild this one. I need to know where to find parts for the engine
or if I would be better off putting a gas engine in.I would prefer keeping the diesel. Is there any publications or clubs that could help with information on restoration? I also need at least one pressed rear rim and 3pt hitch lift arms and toplink assembly. thanks for any info,robk
Don
09-21-2002 04:57:06
 Re: massey harris 44 diesel in reply to robk, 09-20-2002 21:49:10
44 diesel had the HD260 engine, built by continental. you can still some parts for it at NAPA. I think Don L. can fix you up with parts, aswell. The only real expensive part you might need is the injection pump, they can get pricey. good luck
Callie
02-14-2006 06:09:20
 Re: Re: massey harris 44 diesel in reply to Don, 09-21-2002 04:57:06
looking for cam bearings for a massey harris 44
H260 gas. does it even take any?
Tom Harrower
09-21-2002 17:28:28
I was able to find an automotive machine shop that can do just about any repair, and supply just about any internal part for a Massey "H-260"gas engine. Look around your area, you will probably be able to find someone that can do the same for your diesel. Check around in the phone book or heavy duty truck repair ads and ask if they can service the fuel system on your tractor if need be, many people in this field can and enjoy doing repairs on old farm equipment. Keep posting here to let us know how you do, if you need further help, someone will most likely be able to point you in the right direction.....Tom
