Massy Ferguson 125
Brian Young
09-09-2002 09:20:28
My tractor is losing oil pressure due to diesel fuel getting into the oil.I have dumped the oil a couple of times and it has had fuel in it. What might be the problem,how much damaged can that cause to the tractor and what would be the estimated cost to correct the problem?
Brian Young
Danny
09-09-2002 17:01:41
 Re: Massy Ferguson 125 in reply to Brian Young, 09-09-2002 09:20:28
It's been a while since I've worked on a Massey, two things come to mind. The fuel injection pump seal is leaking. The seal will be on the input shaft on the pump when it leaks the fuel goes into the crankcase. If Massey has a fuel transfer pump on the side of the block then they can also leak into the crankcase. If Massey has this I would replace this first (cheaper) I would not run the tractor with fuel in the engine. And the last pump I had the seal replaced in cost about $200.00 next time I will buy the seal and do it myself. If you have to hire someone to remove and replace the injection pump then that will be extra cost.
