Snow Blade mount for front of MF 35.
Farmer in PA.
09-06-2002 22:06:40
I'm looking at putting a snow blade on the front of my MF35. In looking underneath at the front there is a casting with 4 vertical tapped holes, and 2, 5/8 horizontal holes running front to back. Is this casting for anthing in particular? Is it possible to buy a frame work to fit this casting? Does anybody have pictures of a blade mount they have? Thanks in advance. I appreciate any help you can give.
David
09-14-2002 16:33:12
 Re: Snow Blade mount for front of MF 35. in reply to Farmer in PA., 09-06-2002 22:06:40
Bracket and holes are provided for fitting implements to the front, such as snow blades. Them's the boys you use.
The original TE20 dozer blade operates from the rear links by two rods that run from brackets attached to the forward part of the link arms. If you're looking to make something yourself that may be a tried and tested design to steal (if it worked!) Contact me by email if you want more info.
