MF35 governor
Jerry B
09-03-2002 19:43:42
I have a mf35 gas.The linkage to the governor is slop.Above idle the governor automatically pulls the throttle open.Is there a spring in the governor that should offer resistance? If so how much trouble is it to take the governor off and rebuild it? As you can tell I am new to this. Thanks
Gordon-(TN)
09-04-2002 00:23:24
 Re: MF35 governor in reply to Jerry B, 09-03-2002 19:43:42
There is a spring for the governor at the end of the throtle rod up by the water pump.The adjustment for the governor is close to the suction hose (threaded stud with locknut flat screwdriver slot)front of motor.take the slop out first & go easy. hope this helps
Gordon-(TN)
