MF 399
John Essman
09-03-2002 18:49:43
My neighbor has a MF 399 4wd. He is having trouble with the tractor quiting while in the field. At first he thought it was fuel filters plugging up but now the guess is electrical. Problem seems worse when running over rough ground and when tractor is warm. Sometimes after a couple hours it will start again. Any ideas to troubleshoot would be appreciated.
Richard
09-05-2002 17:12:52
 Re: MF 399 in reply to John Essman, 09-03-2002 18:49:43
Depends on age the tractor may be fitted with an eletrical fuel cut of (stops on key,not on a "pull to stop" knob) These can give trouble with cable breakage or the solenoid on the injector pump failing.The solenoid may be unscrewd from the pump,remove the spring and plunger,refit the solenoid body,bleed fuel and retry.the tractor will have to be stalled to stop engine,but will eliminate the problem so you can sort it properly.
