Loaders
Don
09-02-2002 22:35:54
While touring the yard at the local dealer, i found 2 loaders right next to each other, one an industrial, and on the tag it said it was a model 32- would this fit on an agricultural model, or industrial only? and what tractor would it be off of?the other looked to be like it was off a 165 or a tractor of similar size/era, no down pressure, one center cylinder for dumping. The industrial looked to be in good shape, just had a cylinder robbed off for the dump, but it appears to be on the ground underneath the other. neither has a bucket, and looks like the red one needs brackets, I didn't look too closely. Any opinions?
Bob
09-09-2002 17:52:17
 Re: Loaders in reply to Don, 09-02-2002 22:35:54
The 32 fit several tractors in the 135, 165, 202 etc, line, using different front mounts. I have one on my 135 (UK). The UK version has a heavier front axle and power steering than the US version, more like an industrial. Works great with the front pump, but I think it is really too heavy for this tractor. Even with the bucket removed it de-weights the rears enough to lose a lot of traction, and a bucketfull will really do it!
If it has the correct front mount for your model it might work out, but be sure the pump is included, as well as the coupling parts! The couplings are available from Tisco I think, pretty spendy from MF.
